jennis9
Thread starter- Joined
- Mar 22, 2008
- 396
1985, Merc 140, 4cyl -- I/O
1. Action: engine completely stopped three miles after launch at 27mph - motor would turn over but not start
Fix: new sprk plugs, plug wires, distributor cap, rotor and points. fuel filters clean, gas tank full and clean fuel
2. Action: motor starts and idles perfectly, runs normal at no wake appx 5mph - would not power when throttle is engaged forward (bogs out) - checked both gas filters again - checked gasoline for water (negative) -- checked to make sure intake vent was not blocked - then carb begins to spit gasoline
Fix: fuel line tested per mechanic - rebuild carb - replace gaskets and float and lower gas line.
Getting compression but the engine is still bogging out - won;t go past 5mph - compression at each of the cylinders is 120. Our mechanic is perplexed and cannot figure this out. Any suggestions?
