I need catalog experts !!!
tinman565
Changing motor over...both big block mercruisers. Old motor is a 1988 7.4L with the oil cooler on the lower side of block (rh lower if standing in front of it). New 502 Mag had (1990) oil cooler in back. I'm running my cooler the same way it was on the original motor. I'm looking for a part number for the water hose that goes from the thermostat housing down the front of the motor, along the lower side, and to the cooler ( I think it goes to the back of the cooler ). Then I need the hose that goes from the front of the cooler (I think) to the raw water pump. It sorta snakes around the front of the oil pan. Pleeeeeease...somebody's gotta know this set-up, and what the part numbers are. Thanks guys. :redface:
mkast
Re: I need catalog experts !!!
If it's #22,
the part number is: 32-896998
Zackman
What's your engine serial number?​
tinman565
I just sold that motor Sunday..wish I knew the serial number...sorry. How many '88 7.4L motor styles can there be with the cooler on the lower side ? I thought it was one long formed hose that went from the thermostat housing down the front, along the side, and to the cooler ? Thanks for the photo MKAST..but I cant blow it up to see. Oh...and guys, dont forget about the other hose. THANKS !!!!
tinman565
Grrrrrrrrr !!!!!!!!!! I Wish Don Was My Neighbor !!!!!!!!!!!!!!!!!!!!!!
Fun Times
You could try if you still have the origenel drive or transom assy laying around have a dealer look under merc history on merc net punch in one of the numbers off the drive/transom assy, And it should bring up what engine you had and the serial number of the engine the boat started with from day one.:cool:
tinman565
Somebody has to know these part numbers. HEEEEEEEELLLLPPPP !!!!!! :confused:
( I'm gonna get my OUJI board out to try and summon Don )
flargin
Not sure if you have old or new thermostat housing.
Old version here. # 19. part # 32-897142, HOSE, THERMOSTAT HOUSING TO OIL COOLER
or new version # 19. Part # 32-16011, HOSE, THERMOSTAT HOUSING TO OIL COOLER
The pump to cooler is 32-181591 (see new version link above)
Is that what you are looking for?
If not, I am not sure I understand your question.
