neutral switch
poppa_4
Can anyone tell what the neutral switch dose and how it works I have a 2004 gm 3 lit..
Anchor Management 1
Re: neutral switch
It will not let you start the engine while in gear.It has a wire that goes from the key switch to the netural safty switch ,and the out of the switch to the engine.
180shabah
Re: neutral switch
Is this just an FYI question or is there a problem?
poppa_4
Re: neutral switch
My engine won't go in gear, when i put it in gear it stalls out but disconnect it its ok . I just finished replacing the water pump in the leg and now this happen, didn't know if I did something wrong because it worked fine before...
180shabah
Re: neutral switch
So we are talking aboput the shift interupt switch, NOT neutral safety switch.
Were both the shifter and drive in forward gear when you reassembled the drive? If not, the shift shaft was probably not lined up, and might be bent now if the drive got forced back together like that.
poppa_4
Re: neutral switch
This is the switch I'm talking abhttp://forums.iboats.com/attachment.php?attachmentid=29615&stc=1&d=1244023601out guys..
Re: neutral switch
Ayuh,... That the Shift Interupt Switch...
The Neutral Safety Switch is inside the Controller...
Pull the drive,+ See where you screwed up...
Fun Times
Re: neutral switch
Looking at that photo it lookes like the shift cable if off alinment, the push in button on the switch should be as center as you can get it in nutral with the V, it look like it is activated right now, at this point my guess is the shift assy is out of line on the drive to where it hooks up to the bell housing assy. when you pulled and reinstalled the drive was it in forword gear? if not you bent the shift shaft assy.:eek:
poppa_4
Re: neutral switch
Do the boat have to be in the water for this switch to work or will it work on the muffs as will.....
