2002 200hp FICHT fuel assembly replace
bros250
I suffered a failure of the fuel test port on the starboard fuel assembly line which requires replacement. Apparently this is not uncommon but fortunately I did not suffer fire damage as many others have. They have since removed the test port from the new replacement part.
I have the part in hand and am looking for any istallation advice or approximate time to completion. I would describe my mechanical skill level as slightly above average.
Thanks in advance,
jonesg
Re: 2002 200hp FICHT fuel assembly replace
Just take your time, do you have a shop manual, that always helps understand how things fit together.
bros250
thanks it wasn't too bad, about 2 hrs for myself and a friend (boat in water)
