Hello all, I am new here, but have had great luck with other forums on my truck and thought I would try for my boat. I have a 2003 249 Glastron, 5.0l GXi / SX outdrive...
I have a leak from somewhere. When put in the water, the plate on the outer transom leaks by the time it's maybe 1-2 in the water. On the inside it's just below the y-pipe at some plate with 2 screw. I'm fixing to pull the boat out and pull the motor so I can replace what I've been told is the gimbal housing and seals.
ANY !!! advise or help is GREATLY appreciated.
Thank you
Thank you
