pre alpha water pump question.
strombolichef
Today I got the outdrive, what I figured out is pre alpha off the boat.
all came apart with no problem, except the lower half of the water pump, which is plastic.
I didnt want to take a chance on breaking it, because of it being plastic, so left it there. Of course the impeller was toast and the lower of the water pump looks original so I would like to replace it.
Q. does this lower half of the water pump come out? If so, then how?
Thanks.
Bt Doctur
Re: pre alpha water pump question.
Just pry it up with a screwdriver, just remove all the loose debris around it first so it dosent fall into the drive
