115Johnson VRO
jasapaq1
I have a problem with the VRO pump. The problem is with the pump and it is too expensive to replace. I am already mixing the fuel and I want to go to a regular pump. I have been told that the part number #438556 will fit. But that is for an 88 special, would it be enough to power the 115.
By the way it is 1985 115
tashasdaddy
Re: 115Johnson VRO
it will work if you have the block pulse mounting point.
these all have the pulse line fitting, that operates the fuel pump. all for 115hp.
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
