temperedtim
Thread starter- Joined
- May 13, 2009
- 50
So I recently had to remove my engine to replace a busted up flywheel (rust). While it was out I changed the oil, plugs and cleaned her up, its been sitting for 2 years. After putting the engine back in and starting it.....etc, it went belly up. I was revving the engine slowly increasing RPM to see if any noises appeared, nothing to to major, the boat is a hand me down from my father... So anyways it was up around 4000 Rpm and it sounds like a bearing let go. I know that the engine is rated for 4200-4600 WOT...is that the same as a red line on a car and do these mercrusiers (3.0L) have rev limiters? If the engine was old and ready to go I can deal with that but did I do this or would it have happened a week from now if not then? I planned on pulling my younger cousins on tubes and water skis....so the engine was going to be doing some work. Im guessing I was around 4000RPM but I was watching the engine...not the gauges when the noise started. Any idea where to get a decent used 3.0??
P.S. I am 28 years old and have been around engines (car and motorcycle) my hole life....didn't want anyone to think I was some kid out there pinning the throttle just for kicks.
