Flywheel center hub magnet cover
mrod322
My flywheel center hub magnet has a cover with two little open slots i think this is what the trigger reads or picks up. Can i glue this or use some expoxy to put this in place? Does it have a specific mark that it needs to be in a specific place or will i need a new flywheel?
Thanks,
Mike
JB
Re: Flywheel center hub magnet cover
Need model number, Mike.
mrod322
1995 Evinrude 225 E225TXEOB Ocean Pro
Flywheel part number 0583970
Thanks,
mrod322
on the CDI website under troublshooting there are instructions on placing the magnet cover on and it works.
However i now have a slight misfire and it looks like cylider #4 is getting fouled up. If i have compression and spark and that cylinder is getting fouled the only thing it could be is that carb right??? Can it be timing???
Please help.
Mike
