2 hp emergency back up motor?
jayard78
I was thinking about buying a 2hp johnson 2 stroke for an emergency back up for my 50hp johnson. I have a 18ft bass boat that is used on the ocean in Tampa Bay. Will a 2hp push this boat at all? Could it be used as a trolling motor too?
Howard Sterndrive
Re: 2 hp emergency back up motor?
7.5hp minimum... 9.9 better
yes, you could troll with a 2, but no good for emergency on a windy day
jonesg
Its great for those frosty margaritas!
Huron Angler
I would just use a canoe paddle as an emergency backup considering that it won't break, weighs less, is cleaner, doesn't need gas/oil and it will move your boat at about the same speed as a 2hp.
Is the bass boat fiberglass? If it's aluminum the 2hp would push her a little better but like already mentioned- not much help in some waves/wind.
kenmyfam
It will make encouraging noises but not really get you anywhere.
Personally I would go with a 7.5 or 9.9
jayard78
lol...thanks guys, I will keep looking for an electric trolling motor instead and give up on the emergency backup idea.
Huron Angler
I'd recommend a 55lb or bigger thrust Minn Kota- should do what you need just fine on the bass boat. Good luck to ya:)
