I have a 95 Four Winns with a Volvo 5.0fi and SX drive. It is running a little rough when at idle, and if I have the engine in neutral running at say 1500rpm or 2000rpm it seems to run fine, but misses every once in a while. It also seems like the the rpm will drop 100-200 and then come back up, or even go up 100-200 rpm while the throttle is just sitting there. This is on the trailer with the muffs on. When it is just idling , it will idle, and then kinda hit a studder or something, and then correct it self, but it comes and goes. The cap,rotor, and wires are about 3 years old, and I just ordered a new set. The plugs are new also. So I'm not sure what effect that stuff will have on it. But with the efi, and two fuel pumps, tps, and isc, that this engine has all over it, I don't know if I should be looking for something else. I wish I knew someone who was big into mustangs or something and could prob look at this 302 and know right away what is going on.
I read some other post about surging and stuff, and I both my fuel pumps are making noise so I'm not convinced that it is either of those.
Any help would be awesome!
