30hp Tohtsu spark plug wire location
Whoopbass
I just bought a well used Tohatsu 30 hp for $50.
The bottom plug wire from the powerpack was attached to the top spark plug and the top wire was on the bottom plug. Is this correct?
I think its a mid 80's motor. Its blue with a white cowl. Model # M30A2
Serial # 52561.
Do these motors generally have some type of charging system on them? There is a couple wires and a plug that i'm not sure what their for.
TOHATSU GURU
Re: 30hp Tohtsu spark plug wire location
Early 80's, charging system if its electric start.
Whoopbass
Thanks Guru.
How about the plug wires? Top coil wire go to top plug or bottom?
I think their reversed.
Thanks
TOHATSU GURU
It may not make a difference. I think that model fired at the same time. You can call Tohatsu at 972-323-6003 and ask them directly.
