Re: Bunks or Rollers
Tried a roller trailer once before a long time ago. It was horrible loading a semi-V on at the time. I need to admit, I was younger and even more stupider and probably clueless as to what I should of been doing.
That being said,,, since then I've had several bunk trailers and thought they were the best.
I do notice that most seem to be ill-adjusted. Seems like everyone I've ever had (even dealer prepped) was miss matched for optimal support. Often the hull would be resting on the inside /outside edge of the bunk. not hitting full length / width, etc. Easily fixed, but still you needed to position properly and the flatter the hull the easier this seemed to be.
Last winter I picked up a Parker, relatively deep V with a roller. What a BEAST to launch / load. Quickly discovered the trailer was in need of major maint.
Replaced all the rollers, disassembled and greased everything. When I reassembled I noticed the rollers were not in the best of position, so we relocated them. Everything was left "floppy" loose (not rattly).
After $500 and a total rebuild I had to try it out. AWSOME!
With the deep V and the way it's now set, the boat tries to get to the lowest point between the rollers. This makes it almost perfectly self centering even in wind and tide. After several launches I've not been loaded more than 1" off center,,, yet.
Launching is a snap. Crank out, start and warm engine, forward gear @ idle, unhook and away I go.
Loading, idle in between rollers, increase rpm to move S-l-o-w-l-y on, snap on hook, shut it down, 4-5 cranks, safety chain and drive out.
Either way, less than 5 minutes and no strain.
Conclusion (MHO);
Depending largely on the ramps you use, I think I'd lean towards a roller trailer for heavier, deeper V style hulls. However, on a flatter lighter(?) hull bottom I think I'd still go with a bunk as long as it was really low.
I feel the flatter the bottom the less self centering the hull would be with the rollers. Flat bottom, bunk w/ guide-ons. Deep V / heavy, roller with more detailed maintenance.
All my boats on the most part have been trailer queens. Winters (off seasons) they get blocked to take the stress off the trailer and such. I do think the trailer (roller or bunk) offers more support than block. But boats have been blocked since time began and I've seen no issues with the minimal support by this in any of the yards. So I feel that's a moot point anyways.
