is this the water inlet / picture included
actionjackson
'62 rk24 40 hp johnson superseahorse, is this the water inlet, and is it safe to remove and clean behind it?
Mas
Re: is this the water inlet / picture included
Looks like the same inlet as my '80s honda.
MAS
tashasdaddy
1st edit your post and resize your picture. yes that is the main pickup, above the plate are a series of small holes, these are the intake, when in reverse. will not hurt to clean it out. do not damage screen.
F_R
From the looks of it, you might break the two screws holding it. If they don't come out resonably easy, don't mess with it, it isn't worth it. Personally, I've never seen one plugged up inside--and I've seen multi-hundreds of them.
