sunbird 18
- May 19, 2008
- 78
I have a 20' center console with a 225 outboard on it. I had a 150 with a hydrofoil and this new 225 did not. With the new engine, the bow would rise REALLY high getting on a plane and off plane. SLowing down would swamp the heck out of the transom. Going over waves and chop, the bow flops around. With the 150 with foils on it, it didnt do any of this. I purchased the stingray XPII. Installed it. Night and day difference. No bow rise, at all, almost no angle change at all. No swamping the transom when coming off plane, much slower planing speed, trimming the engine up/down has a huge effect, from plowing like mad to pulling the bow way up. Top speed was not compromised, still at 56mph. Huge difference in cutting through chop and wake. The bow stays straight through it all! There has been absolutely no ill effect from installing this hydrofoil other than a 2 degree list to the left when punching it out of the hole. THe list disappears if not using WOT when coming out of the hole or once you are on plane it goes away. It is a very slight list, barely noticeable. Planing speed is so much lower and holeshot draft has ben much reduced. Everyone is always bashing HFs. The HF on my boat works awesome. I am an extremely avid boater who drives/evaluates outboard engines for a living.
The HF did not help my chinewalking/death wobble above 56mph. DIdnt make it worse either.
+1 to the stingray XPII
