77_starcraft
- Oct 8, 2007
- 55
I had two separate issue this weekend on my 77 evenrude 115 that I think are carburetor related;
day 1) rich idle in or out of gear. sound like it running on 2 cyc. Ran OK above 2500 rpm. Float stuck?
Day 2) no more idle problem but loss of power at anything other than idle. boat would barely plane, and surging like whatever is wrong comes and goes.
I think these are related. maybe debris went from keeping the float open into one of the jets. I pulled the plugs and they all look the same, and OK so not sure which carb is the problem.
the boat sat 6 months with stabilizer in fuel. I added 5 gallons of fresh fuel. I have opened up these carbs several times in the last few years. other than the screen on the fuel pump is additional filtration needed so I'm not cursed with carb problems? tank is a custom made from 1/4" Aluminum.
frustrated because this motor is only 50-75% reliable. I keep fixing it but don't trust it to get me back to the dock.
