captain of the seas
Thread starter- Joined
- Apr 19, 2009
- 20
hello i just put a new head gasket and rings in the motor, i had a stuck ring in the 4th cyl giving me low compression, I had a valve job done. It was running pretty good when i discovered this.so i took the motor out, honed the cylinders, cleaned the ring grooves( with limited saticfaction,,See posting "ringing the aq130c") washed out the block and put it back together. when putting the head gasket on I did use A special alinment tool for the head, , I didnt use the volvo special tool , but had one machined at work. I am sure it worked correctly but now i have grey milky oil after 15 min of running. how could i have screwed this up.
