reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I have a neighbor who has a 14' Starcraft Sea Scamp, 14' with a 20 hp max and 700lb rating. He's been running an old 3 HP air cooled motor. I decided that rather than deal with his too small motor today, I'd take my Merc 110 which I run on my 15' jon boat. My boat weighs in at about 575 lbs with two pedestal seats, wood deck and rod holders, and bow mount trolling motor. The little Merc runs that boat at about 18 mph on the GPS with both of us in it.
I figured that in his bare bones V hull it should do better.
We had the two of us, myself at 300lbs, him at about 200, the motor and a 3 gallon fuel tank. The boat is light enough that I can lift it myself, it can't be more than 200lbs or so without the motor.
To my surprise, I couldn't even get the boat on plane with the 9.8 HP?
His boat is about the same width, lighter, and I would think, far easier to push through the water. Both are flat bottomed at the stern. RPMs sounded about the same as on my boat, but the motor stopped just short of getting on plane. Another mile or two per hour and I feel it would be on top, but it labored something terrible. My bass boat is rated at 35 hp, and is too heavy to carry, this thing is light. I even tried a tiller extension I have and it made little to no difference. His boat has no flotation, no floor, no place to hide weight. My Merc 110 has the original 2 blade prop, I have a lower pitch three blade prop I tried on my boat but it gave me too many RPM's at cruise.
I don't get it? I didn't have my GPS with me, but I'd guess it was no more than about 10 or 11 MPH. Regardless of trim, the boat would just plow bow high sinking the stern lower the harder I pushed it. It did the same with him at the tiller and me up front. It felt like I was towing the anchor along the bottom. There were times when the breeze kicked up where I felt like I was standing still. The wind was minimal at best. I can't figure what on that boat has so much drag? I have an older version of that same boat, and the same motor flies on that boat. My older version has more runners on the bottom than his does, but otherwise its the same boat.
I would have bet money that my 9.8 hp would have gone at least as fast as it does on my boat, if not faster. I don't think we were going any faster with the 9.8 than he goes with his old Sea King air cooled motor.
The motor was running good, has perfect compression, and has very low hours on it.
The boat don't look or feel overloaded, at rest it sits fine in the water. It drops in the stern about 6 inches under power. I tried the lower 4 trim pin locations and the lowest was the best. The motor appears to be actually trimmed in a bit looking at it. Which I would think would lift the bow.
