Jeff-in-PA
Thread starter- Joined
- Dec 27, 2008
- 402
Last fall I purchased a 1993 Starcraft 24' pontoon boat. One of the known problems was a gas guage that did not work.
Here's what I've checked so far.
1) Checked for continuity at the tank sending unit. I did get a reading showing some resistance. I took this to mean that that the unit is working. I did check it with the wiring attached but the key off.
2) With a battery showing 12.0 VDC ( which will be replaced) , the key on, I got a reading of 2.19 VDC at the sending unit, a reading of 9.6 volts at the gas gauge itself but no needle movement at all.
Does this sound like the gas guage itself is bad? I did find a NOS unit that matches exactly on ebay for just over $30 shipped.
If not, what should I check next?
Thank you very much
Jeff
Thank you very much
Jeff
