SS MAYFLOAT
Thread starter- Joined
- May 17, 2001
- 6,372
During my seasonal trip to the launch ramp, I ended up in the middle of an intersection of a 4 way stop. Only one brake locked completely. The other side I had just adjusted the shoes out where they barely was dragging on the drum. The one side that was locking up seemed fine and did not have any drag on it.
It is a Float-on brand tri-axle trailer. After doing some research, I have found for the weight that it is carrying that it should have at least 2 brake axles. The one axle has surge style braking.
If I put another set of brakes on the other two axles, would I need to get a bigger master cylinder for the other axles? The master cylinder now is what was on the trailer when I purchased the boat. The master cylinder is actually out of a 1962 Ford Falcon
I have also thought about converting it to electric brakes, but how much current is needed for at least 2 axles? Would it still be good to leave the front axle with the surge brakes and then convert the middle and back axle to electric?
I only tow my boat 2 times a year. Once to the lake and once from the lake. However, I would eventually like to travel to other lakes at a further distance. The braking issue has always made me weak kneed when towing this rig. The truck I use is my bucket truck which has a gross of 11,000 pounds. Add that to the 8,500 pounds plus (depending on the fuel, water, and supply load) I'm getting to close to over 20,000 pounds. Getting this rig stopped is a major concern that I must get corrected
Right now before I act on a solution, I wish to get some ideas and thoughts from some of the master minds here. Thanks.........SS
