woodtick007
- Jul 25, 2007
- 10
I have a 1996 2 cylinder 2stroke 50hp motor that is not making full power. The VRO system has been replaced with the older style fuel pump. The engine had been stored for about 3-4 years and I just rebuilt the carbs along with removing the VRO. I set the carb setting to 3.5 turns and went to the lake to test the motor. Initially the motor would not make more than 2000-2400 rpm at WOT in a 16ft Lowe fishing boat. After while of adjusting the carb jet in and out the motor ran like it should with excellent power, and RPM's of 5200-5400. After running the boat for about 20 minutes I was satisfied that the engine would start at the click of the key, idle excellent, hold steady rpms at various throttle setting and run strong....I loaded it on the trailer and went home happy. This morning I took the boat out to the river to do some Walleye fishing and the engine started with the click of the key.... but would only make 2000-2400 RPMs . I took the cover off and replaced the spark plugs thinking one may have fouled but the problem remained. Can someone please offer me some input on this. Thank You so much. Greg
