javlin1989
Thread starter- Joined
- Apr 16, 2009
- 5
I have a 1989 200 evinrude XP V6 that has been completely rebuilt top to bottom. It sat for a couple years so I drained drained all the gas from tank and carbs new fuel line... removed all the carbs and cleaned them. No clogged jets no clogged oraffices, float level and free... timing is 8 degree tdc at idle and i have tried to adjust the idle speed control and it will not idle correctly. It appears to be idleing around 1600- 1800 rpm on hose but also idels high in lake even making it hard to shift and catch nuetral. and occasionally it sneezes back out through one of the carbs. it has six plastice carbs that the linkage has been adjusted on and all 6 carbs the flaps are closed. I can not figure out how to get the idle down i have adjust idle speed control arm as much as i can anyone ever seen this or can give me a clue??? I am puzzled!
