Evinrude Boater
- Jul 6, 2004
- 1,148
Re: Starflite IV year and locating parts
I think much of the 60s used the same lower end, I mean they "look" the same but there could be subtle differences. I think the 60 through 85 hp used the same unit. The difference will be whether or not you want electric or mechanical shift. You can shift a mechanical unit when it off the motor to try to determine if it turns smoothly. Also, you'll need to get a shift handle, linkage and lower motor cover if you convert.
