Hello All....
Getting ready to tear into the intrument panel but thought I would ask first...1986 Procraft Bass Boat...Fuel, RPM, Speedometer & PSI gauges not working. All fuses on the dash test and look good.
Toggle for Master works but only in the down position (Courtesy Lights), which also does light all the gauges. The Bilge Pump toggle works, as does the Nav Lights switch, but again, only if I have the Master toggle in the down, or Courtesy position.
The Aerator toggle does not work, however, the previous owner put an aftermarket aerator control flush mounted on the right wall near the throttle. This control is a little more advanced then the toggle - Manuel and Auto settings, as well as a timer, so two trains of thought...maybe he put this in because it was cool, or maybe he put this in because the toggle quit responding and when he re-routed power, he interrupted something.
I am probably putting too much into this for now - as it stands, I don't believe I have bad gauges since all of them are out...I have poked several places with the volt meter, including the circuit breaker coming from the battery...I can't find any in-line fuses and again, the dash mounted glass fuses all test good.
Is there something simple (God, let it be something simple) I am missing????
