Newbie here,
I have a 1975 70hp Johnson that shifts in gear fine (both forward and reverse) but as the rpm start to climb it acts like it slips in to neutral and the engine just rev's up. Put the throttle/tranny handle back in neutral then back in to forward and the tranny locks again until you try and give it fuel.
I search the forum and only found one thread that mentioned this problem (actually the exact same problem
My son adjust the transmission shaft and it appears to be adjusted right, but I just don't know. I read that the prop hub could possibly be spun, but I do not understand what that is.
Engine is on a tri-hull 1975 15' Glastron and was running great until just this morning.
Thank you for any help in troubleshooting.
