radiomanlm
Thread starter- Joined
- Mar 24, 2009
- 4
Hello,
I have a 1999 johnson 35 hp 3 cylinder that has been giving me fits.Last year it would stall out and we discovered if you lightly tap on the electronic module on the side of the motor it would straighten up and run o.k. I took it to a marine dealer and they confirmed and replaced the module and checked it out.They said the carbs needed rebuilt before it would run correctly again.Their rate was more than I had to spend so I found another dealer that charged less.Long story short he rebuilt the carbs and informed me that they were like new but he cleaned them and put in new kits anyway.It still wont run right.It runs on the middle cylinder fouls out the plug on the top one and the bottom one still looks new no gas on it nothing.compression is around 125 on all cylinders spark is good and if you slightly choke each of the carbs with your hand gas is present in the front of them.Is there something Im overlooking or is there a common problems with these engines that would cause this.
any help would be appreciated.
thanks
thanks
