1994 crownline
cooter2506
I am looking at a 1994 Crownline 182 BR. What is the weight of the boat only? Ive looked and can not find that info. Trailer is the original it came with and has a 2800# capacity. Thanks in advance
Re: 1994 crownline
Ayuh,... Just a WAGuess,.... 2000lbs...
grego
Re: 1994 crownline
Be sure that you use, a good boat surveyor
cooter2506
Re: 1994 crownline
Already was surveyed. Surveyor said it looks like a 2004. and has 190 hrs. He went as far as removing risers and everything. said it is clean as hell!!!!
SuperDaddy
Re: 1994 crownline
Check www.NADAguides.com, and click the link at the top for boats.
Look up your boat, and in the information given you should see the "dry weight".
