no luck finding the right grease today to grease outdrive
weider1717
Per the manual all the zerks on my MR outdrive requires 2-4-c grease and the gimble bearing requires u joint/gimble bearing grease.
Went to walmart they had nothing that said 2-4-c all they had was general marine coastal marine grease and super tech general marine grease....both said for like trailer bearings etc..
so where in the heck without ordereing do I find the correct grease and also not going a hour drive to a boat marine seller.
also if I order off iboats. they have quicksilver 2-4-c grease...but what about u joint/gimble bearing grease...what are you guys using that iboats has to offer?
Don S
Re: no luck finding the right grease today to grease outdrive
Go to your nearest Merc dealer, or call them and have it sent.
weider1717
Yeah I'll just make my way there this weekend. Ok I know I'll need the quicksilver 2-4-c for all of the zerks except the gimble bearing zerk according to the service manual...question is does quick silver make a grease for the u joint/gimble bearing?
if so what is it? I haven't found it on iboats.com's marine store...
thanks don
Don S
They are the ONLY ones that have it as far as I know.
PS: Pick yourself up a tube of Spline grease at the same time. It's used on the coupler splines. It came out after the manuals, so you won't find it there.
weider1717
thanks, but I'm still unclear on the u joint/gimble bearing grease...haven't seen such a animal thats made by quicksilver mercury....haven't even seen it on iboats.
I know I need their quicksilver 2-4-c but according to the manual you use a different grease for the u joint/gimble bearing.
Don S
iboats doesn't carry all the Merc OEM stuff.
I should have said "Mercruiser" is the only ones that have it.
sickwilly
Do you have a bass pro shop close by? I picked some up there. I believe it was called quicksilver u-joint and gimbal bearing grease. I got 3 3 oz. canisters for $7 bucks (I think). This was in Feb of 2009. Lots of other good boating goodies to pick up too.
sickwilly
Oh yeah, they have the 2-4-c too, but I got a squeeze tube of that from my local merc dealer.
bpmcl00
i use multipurpose marine grease from walmart for all my zerks except u joints and splines..
just as long as i grease often i will be fine..
as for u joints, mine are sealed so i dont need to grease them..
Ayuh,... Exactly...
V
V
V
V
V
V
V
V
V
V
V
V
weider1717
forgot about bass pro...but it's about 2 hours from me but I can order on there they usually are pretty cheap. thanks
Johnshan1
How essential is it to use actual propshaft grease on the propshaft? Seems like grease is grease?
weider1717
what the hell! drove nearly an hour to a merc marine dealer and they didn't have either grease I was looking for! they had the merc oils and gear lube but not any of their greases...lol I give up!
weider1717
Next time, give them a call on the phone first before doing all that driveing.
Let me guess, you forgot to have them order you some, didn't you?
http://www.mercurypartsexpress.com/us/lubricants-c62.html
Don, just ordered some I went to wholesalemarine.com and noticed they had both the correct 2-4-c and the gimble bearing grease...
so I ordered both! weird thing is I ordered both types in the 3 pack of 3.5oz tubes...the 2-4-c and the u joint/gimble bearing grease were the same price of $8.73 kinda weird huh? usually the 2-4-c is a lot higher..
whats also weird is I ordered the actual mercury/mercruiser brand of them part numbers 92-802861A-1 for the 2-4-c and 92-802871A-1 for the gimble bearing/u joint grease...and these part numbers/mercury brand ones were cheaper on their site than the quicksilver version of them?!????
I know quicksilver packaged things and mercury packaged things are the same really but I woulda figured the quicksilver woulda been cheaper but on their site the mercury brand was..
I might call them tomorrow to see if their site is right and that I am actually getting what it said I am supposed to receive because that seemed a bit off to me.
any thoughts on it?
weider1717
ttt
