I have a 98' Force 120hp OB 4cyl with water on the #1(top) sparkplug and motor was working 90% top end prior to finding water.
I have a manual and am going to change head gasket, thermostat, and thermostat gasket, hoping no cracked block. Wanting know of any unexpected steps in process.
Manual indicates remove thermostat, remove cylinder head bolts, remove gasket and its residue, use emory cloth, check for warpage, apply sealant and gasket, install/torque cylinder head bolts in order, and replace thermostat and gasket.
Are there any steps I should know about that above don?t cover?
Is my speedometer not working possibly related to same problem?, as pitot tube from motor to indicator already checked.
I appreciate any advice, Thanks
