15 hp Gamefisher Questions
chris88
I just bought a boat and I would like to know what year and some other answers. The Model number is 225587151. It seemed like it was running hot when i put in the garbage can. I just had the lower unit off and the impeller looked good and all the passages looked ok. What else is there that I can check before I put it in the water. Is there a T-stat on these? It seemed to run alright and everything looks good exept it seemed a little hot for the little time i was running it. Maybe I was just paranoid of it. <br />Thanks<br />Chris
ratracer
Re: 15 hp Gamefisher Questions
You may find some of the answers to your questions by going to http://www3.sears.com and searching by model #225-587151. If nothing else you'll find diagrams and parts lists.
CATransplant
Actually, you'll need to replace the hyphen with a period on that site for the model number.
chris88
More trouble, I just put it in the water and it overheated. It pumps water when im in neutral but once I start moving it doesnt pump water and it overheated. Is there anyway to get more water to come through the intake? It will only pump water for a minute or so that it stops. I cant figure out whats wrong with it.<br />Chris
