ryan_eyres
- Jan 27, 2008
- 80
Hi all,
I'm in the process of restoring my 1978 Reinell 1701 - See the thread here: http://forums.iboats.com/showthread.php?t=237400
When I bought it, it came with a cracked block, and a complete outdrive assembly in the boat. Also, it came with a rebuilt shortblock 140, and an extra leg upper and lower unit.
I have gutted all the parts from the boat, and the boat is at the point now where I'm ready to re-install the engine and outdrive.
Here is my question:
What parts should I be ordering to rebuild the outdrive?
There's three pieces to the outdrive, the lower unit, the upper unit, and the piece that bolts to the engine and sticks through the boot in the transom (what's this called?).
I'd like to replace all the parts that I should, while I'm in there.
So far, my list includes:
Seal kit for upper and lower unit.. (does this include seals for the
piece that bolts to the engine and sticks through the transom?)
Impeller
Ball Gears
Rubber boot that goes around leg and screws into transom.
I think I also need new shift cables as the plastic sheath that
they are in is cracked.
Any and all advice and suggestions would be appreciated.
Thanks in advance,
-Ryan
Impeller
Ball Gears
Thanks in advance,
-Ryan
