Matthew A.
Thread starter- Joined
- Jan 24, 2006
- 232
Upon having to operate the motor at 2000 rpms or so to establish the 5 mph speed limits, the motor runs rough. By rough I mean the motor tends to vibrate more then normal due to a very light yet, "continuous" [if that makes any sense] hesitation or stumble between the motors normal vibration occillations. I recently gave the carbs a cleaning and reset the air/fuel mix. If one determines proper air/fuel mix by full throttle starts from 0 mph to full plane, the motor has no hesitation, stumble or cough whatso-ever. Air screws are set at 1 1/2 turns out. Fuel bulb stays firm, inline filter between pump and carbs remains full. Plugs are new and after a full day of use as well as after rinsing the motor at home for 10 minutes or so, plugs have very little if any deposits. The carb butterfly valves are all in sync with eachother. Electrical conn. good. Compression good.
The motor starts and idles beautifully. Runs at all other rpms beautifully as well. Only running at 1900 to 2100 rpms does the motor run rougher then it normally does. Almost as if it's just unhappy at that rpm.
I am fairly certain its a fuel circuit issue. Perhaps one carbs air/fuel mix not quite right. Is it advisable to make adjustments to the air/fuel mix while the motor is running and under load at 2000 rpm? Could there be another cause I may be overlooking perhaps? Worn reed pedal?
