evinrude timing
RON MCFARLAND
I Have A 1971 50 Hp Evinrude That Will Not Start I Have Good Spark At The Plugs And Getting Gas To The Plugs I Put On A New Fuel Pump And Rebuilt The Carbs When I Get No 1 Piston Top Dead Center The Crankshaft Mark And The Pointer Dont Line Up It Is Off 3 Or 4 Inch Anybody Know What May Be The Problem Thanks Ron Mcfarland
Randybeall
Re: evinrude timing
You may have a key sheared in the flywheel. First question is do you have an Evinrude shop manual? If not, get one before proceeding. You need to remove the flywheel and it is no easy task. The nut comes off then you need a specialized puller to pull the flywheel off the taper of the crankshaft. If it comes off with out the puller you can be sure the key is sheared. Let us know what you find. Also Welcome to Iboats!
Mas
Re: evinrude timing
What's the timing supposed to be?
Your timing will likely not be 0 degrees top dead center...maybe 30 degrees BTC??? You will have to look up the info.
So, it should not line up as you might expect. Look up the timing specs!
Or, are you saying that your TDC #1 does not line up to the 0 reference point????
MAS
RON MCFARLAND
Re: evinrude timing
thanks guy i got the flywheel off the key was sheared put one in and got it to run i do have a manual the compression is good and within specs thanks again this is a helpful forum
wilde1j
Re: evinrude timing
If you didn't torque the flywheel nut and make sure the taper was clean and dry, it will shear again, perhaps wrecking the crankshaft.
