Quick Question on Johnson Outboard
tex599
I am needing to get the carb kits for a 1992 60hp engine, the parts diagram shows early model carbs and late model carbs. Not sure which my eninge has, both diagram carb explosions look the same. My model number is J60TLENE and serial number is G 03165118. Any help would be greatly appreciated.
Thanks,
Tex
tashasdaddy
Re: Quick Question on Johnson Outboard
they are two different carbs, look at the diagrams, they have different connections for the primer fuel line connections, is the easiest way to tell. http://forums.iboats.com/showthread.php?t=290315
the one on the left is the early carb, the one on the right is the late carb.
seahorse5
Thanks,
Tex
It doesn't matter which carburetors you have, both carbs use the same repair kit #396701
To tell the difference, the late model carbs have a black flat plastic plate on the very top held by 4 screws.
tex599
Thanks for the quick replies.
Thanks
Tex
