FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hi guys, I have an old aluminum boat with some cracks in the bottom from dragging over and hitting rocks. Have any of you ever used JB marine epoxy to repair?
My buddy uses a small jon for hunting and drags it with the same result.
I took it into work and welded the cracks then welded on some thick aluminum angle on the spots that rub, you should be able to have the same thing done to yours.
I am a JB junky so I wouldn't have a problem with that either, just make the repair alot wirer than the crack and kinda thick.
If you can find some you may even JB some angle on it.
Aluminium is easy to work but not that easy to weld. Best bet if you continue to use the boat that way weld some thicker aluminium plates on the spots where you hit it most. Have the hull a bit thicker and you will be good for a long time. Patchwork is always more expensive in the end as you have to do it over and over again.
I know from my old boat. A 14m aluminium sail boat. We patched some stuff after we hit a big chunk of wood and the patchwork had to be redone after only 3 months. Better to weld in the first place and have it done forever.
Thanks, sounds like the same problem. The crack is at the end of a piece of angle welded earlier. The problem with welding aluminum is it is always thinner at the edge of the weld.
Indeed.That's what I meant. If you make parches you will always have problems again. So what I meant to say is to take a big chunk and protect the whole bottom part where you hit most. Don't know how big your boat is but normally it is worth the hassle. It is easy to work it into a certain form as you have a formed hull already and then weld the edges which have to be in not strained areas.
