Welding on new skeg
seagull369
I was wondering if anyone has ever tried welding on a replacement skeg on a mid eighties-ish Force. My 125hp's skeg broke off (bought it that way) and I tried (TIG) welding on a new piece and but just couldnt get it to stick.
Before I go playing with anymore, I was wondering if anyone knows if the aluminum on this thing can even be welded. Thank you.
jerryjerry05
Re: Welding on new skeg
Yes they can be welded.How much skeg is left? They sell add on kits if there is enough left to screw to.
The prop repair shop that I used did all my skeg repairs.May be your local prop shop can help.Jerry
Barnacle_Bill
I've had prop shops replace them (you have to take the L/U to them) and I have used skeg guards. They work great if you have a couple inches left to bolt them to.
Frank Acampora
The aluminum alloy used contains silicon which makes it more difficult to weld than other aluminum alloys. It is, however weldable with no special problems. Extruded plate can be welded to it.
It does not show in the photo but the engine in my avatar actually has a nice chunk of 3/16 plate welded to it. Way, way, stronger than the original. I did accidentally hit a rock with it and it only put in a nick that I was able to power sand out with my belt sander. As I have said in another post, I originally sent it to a welding school for free repair. You get what you pay for. They got it on crooked and tilted. Not a lot, but it bothered me so much I took it to a professional welder. 100 bucks later it was on straight and plumb, with a nice fillet at the joint with the gearcase. Well worth the price as far as I am concerned.
If you are not an EXPERT welder, this is a case where it is worth it to pay the money.
A poor welding job can make the aluminum porous and of course, we don't want that on an under-water part.
If you have not done so yet, drain the lower unit. This will prevent the oil from expanding past the seals, possibly ruining them, and also causing a fire hazard.
7355hpchry
Last week I made a repair on my lower unit with Muggy Weld Super Alloy 5. It melts around 600F. It worked FANTASTIC on my 1974 lower unit. I had to "Fill in" one of the screw holes for the water pump.
After the weld, I drilled and re-tapped the 1/4" threads. The repair functions perfectly. I'm am in NO way a professional welder the Super Alloy 5 is more like soldering.
