gear lube
PmDavis300
can i drain the lower unit lube for the winter then refill it in the spring? or do i have to refill it right away?
seahorse5
Re: gear lube
For an article on gear lube testing, get the December '08 Bass and Walleye Boats Magazine. Some of the best known brands don't do as well as you think they would.
twostroke87
Re: gear lube
definetly refill it, those gears are just iron, if you leave it exposed to air you give it the opportunity to rust.
SKEETR
Re: gear lube
Drain it and refill it in the spring.
1946Zephyr
Re: gear lube
It depends on how good the oil was, when you drained it. If the oil had no water in it, then you can get by with draining it and refilling it in the spring. If it drained with a milky look, then you better flush it out real good and refill it with good oil.
Don Hansen
Re: gear lube
If you are going to drain it for the winter and fill it in the spring, here's what I would do. Hang a BIG tag on the front of the motor saying "NO OIL IN LOWER UNIT".
Don Hansen
Rick.
Re: gear lube
Amen to Don Hansen's suggestion. I can see no reason to wait until the spring unless you think the price of oil is going to continue it's downward trend. LOL Are there specific reasons to wait? Rick.
kenmyfam
Re: gear lube
Don Hansen
Agreed !!!
Tim Frank
Re: gear lube
Don Hansen
I'd go a step further....take the prop off and then hang the tag on the bare prop shaft.
It is SOOOOO easy to plan to complete a job in the spring and then get "spring fever" and try to get back on the water ASAP so some things get forgotten.
On the other hand, filling the lower unit now costs little, and if you want, you can still change again in the spring.
kenmyfam
Re: gear lube
But best of all, fill it now and save the worry !!!!
david_r
Re: gear lube
whats all this talk about puttin it up for the winter?
we do a lot of fishing during the winter in oklahoma, especially catfish, ive even had to break ice around the ramp to get the boat in the water a few times...........you just dont go as fast and you sure dont want top fall in.
as far as leaving it empty DONT. its a costly mistake if some thing happens and you forget and your sign disappears........it mysteriously disappeared is how the story would go around my house.
Rick.
Re: gear lube
For all who think it's alright to leave it empty and rely on memory check this one out. "Boy, did I pull a dumb one!" Rick.
