wildmaninal
Thread starter- Joined
- Jul 14, 2007
- 1,897
I'm trying to fix up my bass boat trailer a little bit, I have a 15 ft tri hull on the trailer with an 85hp on it so I have some weight on the trailer. My old hitch was welded on, worn out, and was only a 1 7/8" ball size so I wanted to update also. My father seems to think that I would be alright just bolting the hitch on, which I had to drill holes in the trailer in order to bolt it on didn't like the thought of that because I'm thinking the holes can weaken the 2x3 tubing. But......I'm wondering if I should take the extra step and at least weld the hitch on as well.
Do YOU (is your hitch) just bolt the hitch on? or..... Do you weld your hitch to the trailer? or..... Do you bolt and weld the hitch?
I don't feel safe with just 2 (maybe 7/16" to 1/2") bolts holding the hitch on. I also would dread having to replace the hitch if I did weld it on. Thought about tack welding the nut to the bolt as well where the nut can't come loose.
Just wondering what steps you would take. Should I be alright with just the bolts? Yes I have a safety chain.
