Light brown water from Exhaust
lmannyr
Master Chief Petty Officer
I ran my 5.7 Merc A 1 today on muffs after sitting for 2 weeks. I noticed light brown water come out of exhaust at first then it cleared up in less than 1 min. I flush for at least 15 min after my outings on the ICW. Engine seems to run smooth otherwise. 4k+ rpm.
Is this normal?
Thanks!!
Don S
Re: Light brown water from Exhaust
Yes, it's rust and it's normal.
lmannyr
Thanks for the quick response don
RUST! Oh boy. Anything that can be done to prevent the rust?
THANKS!!
Don S
Yea, run oil thru the cooling system, then NEVER get it near the water again.
chiefalen
He does have a sense of humor i knew it.
Maybe mrs wizard was good to him last night.
Fishermark
I ran my 5.7 Merc A 1 today on muffs after sitting for 2 weeks. ....
Is this normal?!
Being from West Palm Beach and the great salt sea - it doesn't matter what you do - it will rust. Flushing it will help, but everything will rust and need to be replaced eventually. ;)
bigbrownbuku
or you could find some stainless risers and change to a full fwc system.
lmannyr
Whats the price difference between SS and reg risers?
Thanks..
Thanks..
Ayuh,...
Somewhere between a couple hundred to a few thousand,... Depending on the Model....
lmannyr
depending on model? umm.. it's for my 5.7 merc. No need for upgrade except for possibly closed cooling when the engine is toast.
