fiftiesoutboards
Thread starter- Joined
- Apr 11, 2008
- 27
Gentlemen,
I'd like to convert my QD-14 back to a short shaft, but have been unable to pull the driveshaft from the powerhead. I have separated the lower unit and have the powerhead off so I have access. I have tried soaking it in penetrating oil forever, exerting hammerblows to visegrips on the shaft (I don't need this driveshaft anymore), using high heat, and still the bugger is like it's welded in.
I've been told of people cutting off the shaft close to the powerhead and drilling and tapping a hole to use a bolt to pull out the stuck section, but wondered if there will be enough room to run the tap through far enough.
I also thought of cutting the shaft off in a similar fashion, and drilling a series of smaller holes along the diameter to cut the plug in half, so I could pinch together the halves and break them away from the socket. I figured this way I wouldn't have to tap any threads.
Also, is there a short driveshaft tube (the cover that connects the pump housing to the lower leg) to replace the 5" one that my motor had, or do you not use one on a short shaft?
Any advice will be appreciated. Thanks, 50's
P.S. A good thing is that the motor must have been extended from a short at one time 'cause it has the long shift connector.
