Any aftermarket exhaust elbows?
guiness92
Hello, my name is Ron and I am a new owner of a 90' 17' larson with a 3.0 mercruiser alpha one motor. I have just got done doing alot of work to this boat because the previous owner let it sit for about 6 years. The boat runs flawlessly now and is very fun to cruise around on.
Only concern I have is that the exhaust elbow was in REALLY bad shape. The ports were rusted solid with crap and even after soaking in muriatic acid for 2 hours, I still had to chisel them clean. I was wondering if anyone made an aftermarket elbow for this motor because it seems to me that this exhaust setup is very restricted. Any input would be appreciated.
Haut Medoc
Re: Any aftermarket exhaust elbows?
Welcome to iboats.....:)
Muratic acid is a temporary fix, replace it before it fails & you get water in your engine.....
You might be able to get it here....
Ebasicpower & fredwarner1 on ebay should have them cheap as well....;)
Ayuh,...
That Crap you were Chiseling out,.... It Used to be Cast Iron......
You're on Borrowed Time....
While there Are aftermarket manifolds available, from various sources,...
There's No freer flowing, Hotrod manifolds available for your motor....
chiefalen
How was the manifold? Me thinks your on borrowed time with that also.
What temp are you running at. 140- 190 max. Anything over 190 and your in trouble.
guiness92
The manifold was in excellent shape. No flaking, corrosion or anything. Almost looked brand new. The elbow was definately bad though. I chiseled the ports and reemed it with a wire wheel and honer. It is ok for now but needs replacing asap. We only have a few weeks left in the season here till noone will go out on the boat with me. That was the reason for this thread, instead of just getting the same oem elbow, I was hoping that there may be some sort of aftermarket elbow that would allow more flow and possible increase in performance.
Thanks for the responses and awesome site!! I see myself spending alot of time here and reading.
guiness92
The boat is now running at a steady 145 - 150 at all rpms.
JustJason
Well.... GLM has their flangeneverflat series, and their ever popular leaksalot serious.
If your looking to replace it a factory riser is the way to go.
You may want to seriously consider replacing the manifold along with the riser, as they tend to go in pairs.
chiefalen
Thats it Jason same thoughts as me.
Go o.e.m.
Been hearing alot of horror stories lately about china made stuff.
Starters, water pumps, elbows, manifolds.
I just got rid of 2 quads real p.o.s both of them.
JustJason
yep.... even the milk is bad :)
billbayliner
There are some GLM's on Ebay right now for $85
"MERCRUISER EXHAUST RISER ELBOW FOR 2.5 3.0 120 HP 140HP"
chiefalen
Osco was ok 3-4 years ago, today who knows.
