mercruiser starter replace?
achris
More fish than mountain goat
Re: mercruiser starter replace?
It's often easier to get to the inside bolt from the other side of the engine, under the sump....
Chris...........
mthieme
I just replaced mine two weeks ago.
I simply reached under from the port until felt it. It's only 3" away from the other bolt.
Of course access is an issue depending on what kind of boat you have.
betayv
ummmm under the sump? can you explain better for me. sorry...
mthieme
That explains why you can't reach the second bolt.
You must have some longs arms!
BTW, there will three or four wires attached to the solenoid under there too.
Dunno if I'd pull the engine...manifold maybe.
achris
....Dunno if I'd pull the engine...manifold maybe.
Good thought... But I would definitely be doing SOMETHING to improve access...
Chris.......
mthieme
Yeah, now I know where the term Hell Hole came from.
Must be a lot of dead space in that hull (?).
achris
I have actually heard of people cutting a hole in the bottom of a boat to get access to a starter motor!!!
Chris......
betayv
hey thanks for the help today I will go and keep looking for a way to take out the starter I will keep you guys posted.
mthieme
Yeah, let us know. It might look harder than it actually is.
If you do have to pop the manifold...it's not a big deal. 8 bolts (I think), a couple hose clamps and a gasket. If you do, it might be worth while to separate the riser to take a check the water jackets.
Fishermark
Chris......
:eek:
For the record - I assume Chris is not suggesting that course of action. Pull the engine? Maybe. Cut a hole in the bottom of the boat. Uh... no.
mthieme
I think he was merely citing an extreme someone (else) has gone to.
But I can't wait to read his response !!!
achris
Chris......
No, it wasn't me!!! :eek:
Merc dealers in Australia have an annual conference.. It was something that came up at one of those....
Chris......
betayv
hi there guys well nothing yet Im in the point to give up I took the riser and manifold and no no space no even a hole where I can see the bolt!! any ideas please help thanks.
gene8084
Try working with two people.
If you got one bolt out you should be able to feel under the starter for the other.
Use a deepwell socket and get yourself a extra long extension (12"+) plus the typical 8" extension that comes with a socket set.
One person holds the socket in place.
Best to put the bolt you can reach back place (snug) until you get the lower bolt out.
Good luck.​
mthieme
Can you get your hand under the starter at all?
betayv
no I dont even have the space to reach for the other bolt!!!:mad:
achris
attachment.php
:D:D:D:D
