BR
Thread starter- Joined
- Jul 16, 2008
- 55
I?ve been working on ?76 Merc 850. Motor would start & run but not idle. I had good spark to all four cylinders. Compression is even on all four 120 psi +/- 2psi. I removed carbs & cleaned, replaced fuel lines, etc. Still wouldn?t idle or even run below 1,000 rpms. I tried the old trick of placing my hand over the carb throats while running. Upper carb had vacuum and would stumble when I did this. Nothing on lower carb. I suspected an air leak into crankcase, maybe a bad reed or a crank seal. Upper two plugs were oily and wet, lower two were clean & dry. Seems the motor?s only running on top two cylinders. So I tore it down & opened up the crankcase to look inside. What I found was a bit of rust stains on the lower end cap and some water in the crank seals leading me to believe that the seals were at least allowing air and possibly some water into the crankcase. I believe this may account for the lower 2 cylinders not running. The lower bearing seems ok ? it?s not rusty and it spins freely. The real surprise came when I inspected the pistons. All seem to be fine except for #4. The piston skirt is gone in the area below the hole for the wrist pin? Isn't the wrist pin 90* from this hole? (see photos). I did not find any fragments of the skirt in the crankcase. Question is where did they go? Into the combustion chamber and out the exhaust? Don?t know how long ago this may have happened or whether it has any effect on current poor running symptoms. Any ideas what may cause a piston failure like this? What should I do to repair? As I said earlier, I have good, even compression even on #4. Should I replace the #4 piston anyway?
