This motor has had limited use over the years, and has performed well to date. But, all of a sudden started running on only 1 cylinder. The spark was OK on both cylinders. The compression on the top cylinder tested at 90 psi and on the bottom cylinder at 30.
I suspect broken reeds. Do you reach them from the carburetor & intake end or the top end?
I would appreciate any help I can get.
