what year heads are compatible
66 joe
I believe I have a 97 johnson 112 spl. Im looking into replacing pitted up head on cyl 1/3 side. Question is what year range should I be looking for?
found no. 326505 stamped on head w/ d 4 also on it.
Thanks,,,,,,,,, Joe
Dhadley
Re: what year heads are compatible
If your port head (2 & 4) has a 326505 head then the one you need is a 326506. Whatever the number is on your port head the head you need will be 1 number higher for the starboard side.
66 joe
yep,,, the good side has cyl 2 & 4 is # 326504; Do I need a specific 97 head? Im not even sure the motor is 97, was bought in 96.
Dhadley
It doesn't matter when it was made or what model it is. If your port head is 326504 then you need a 326505 head. You need to match what is good. If you call a salvage yard they'll want to know the number on the head. Most will ask what you have on the other side. Just call someone like Superior Marine (800-338-9281) and tell them you need a V4 crossflow head #326505 and you'll get what you need to match what you have.
