I Have One Dumb Question ! You Have Been Great And Helped Me Get This Running Great !! Mr Moderator With The Same Motor As Mine Can You Tell Me Where To Set Idle Higher Rpm As The Motor Now Will Not Idle For More Than 30-45 Seconds Then Dies And I Have To Use Choke To Restart ??!! Do I Have Some Other Problem Or Just Need A Higher Idle ?? This Only Happens When I Go To Dock After Running 1-2 Hours @ 2000 To 2500 Rpm Then Go Home And Have To Be Very Care Ful Not To Hit Dock As Motor Dies At Lowest Speed !! WHERE IS IDLE ADJUST SCREW ? OR IS THERE ONE ?
Thanks Again !
Ps. Put On New Fuel Pump And Plugs From Advice On Myprevious Post And Was Running Great And Still Is But, Start And Idle Are
Rough !! Joe 8/22
Thanks Again !
Rough !! Joe 8/22
