'98 JOhnson 90 shift linkage
bluerunner
Trying to disconnect to pull lower unit off. Manual and what I have seen online only makes mention of pulling the cotter key out of the transfer bar. This does nothing to disconnect the linkage. Any help would be appreciated
clanton
Re: '98 JOhnson 90 shift linkage
Remove the key, push in on the shaft, shaft should move inward 3/4 inch.
The belcrank under the carb is split. Still a bear sometime
bluerunner
Push in as in further up under the power head, or a side side "in"?
clanton
I say push inward in the shaft you removed the clip from, after you remove the clip. It works like a shaft inside a short shaft. when you push inward, no pressure on gearcase shiftrod, or it will not always disconnect,
clanton
Stand on starboard side of engine, push shaft to port side.
bluerunner
Got it, was kind of a pain in the buttocks but it came free and lower unit is free.
Thanks for the help
clanton
If that was fun, wait until you reinstall.
