18 hp 1973 evinrude lower unit reseal
huntxtrm
Can anybody tell me anything I should know before I attempt to reseal my lower on my 18 hp 1973 rude. Is it a simple teardown and reseal, or is there more involved.
Vic.S
Re: 18 hp 1973 evinrude lower unit reseal
That's what I'd do and cross any bridges when i came to them.
Be sure you know where to disconnect the lower shift rod from the upper. Be sure you know where to obtain the seals, including the "spaghetti" seal between the top and bottom halves of the gear case and any O rings you disturb. Don't overlook the washers on the drain and level plugs.
Change the pump impeller while you can!
Pulling the driveshaft from the crankshaft may well be difficult.
A manual would be advisable
huntxtrm
Thanks for the info, I was just making sure no springs or other stuff is gonna go flyin when I crack it open. I am lookin for a repair manual, any suggestions? I heard go with oem manuals only, Is that true?
Vic.S
Oem manuals are always better as you'll get one that specifically covers your engine or at least yours and one or two others that are more or less the same.
You'll find exploded diagrams and parts lists HERE
or HERE
They can be useful but no substitute for a manual.
(what manual did I buy? ..... None but I'm the sort of person who takes things apart to find out how they work)
