81 50hp cracked block
bj_sen
Have a 81 50hp electric start Johnson with a cracked block. I need to know what years are compatable to find a donor block.
thanks
tashasdaddy
Re: 81 50hp cracked block
BRP says these are all equivalent:
Part Number: 0389357
Description: CYL,C-CASE AY
Pack Qty: 1
Dimensions: 19.50 x 15.50 x 14.00 (in)
Weight: 29.46 lbs
Equivalent Parts: 0392633,0395359,0395547
bj_sen
There is actualy one crack and one hole (about the size a golf ball). Both sections of the crank case is damaged.
Thanks for your help with the part numbers.
