stoneagent
- May 15, 2008
- 6
Testing 70 HP motor. Started engine with water hose hooked up to it. All indications of cooling. After a few minutes of running I heard an alarm go off at the console so I turned off the power. I went back to the motor and looked around, checked anything that I thought was the problem. I let the motor sit for awhile. When I tried to start it again, it clunked like the battery was low. I went back to the motor and when I tried to turn the flywheel it would only go one revelution and strike something. I turned it back the opposite direction and the same thing occured.
I will add that when I started the motor, it sounded as if it wasn't producing full power. I reved up the motor to see if the sound would change. After a few second of higher RPM is when I saw the water not coming out of the hole from the housing of the motor. Then is when the alarm went off.
Does anyone know why after turning off the motor it now has something preventing it from working.
Dennis
Dennis
